I want to switch the focus from one button to the next. I can set the Focus on to a widget as an action, but the previous button also has the focus highlight after I do that. Since Axure can’t keep Focus on only one widget at a time I would have assumed it would make sense to have an action to unfocus the previous widget. Nope! I see no way in the action to do that! Is this yet another secret, special hidden, thing that is not done intuitively?
No way to UN-Focus!
huban
#2
Setting the focus on one widget should remove it from the other. Is there any chance you can share an .rp file of what you’re seeing?
Does the focus styling change if you hit the “Tab” key?
