OnFocus action on Text Area looses focus
|I have made a control with an text area and a Label. The Label is hidden, but when the OnFocus is triggered the Label is made visible. However when that happens, the Text Area triggers the OnLostFocus immediately. When I do the same with a Text Field, the OnLostFocus is not triggered. Why is there a difference in behaviour?
Hmm, does the OnFocus event that shows your label widget set focus to any other widgets? If you check the “Console” tab of the prototype sidebar in the browser this should help to identify whether an interaction that fires after OnFocus of the text area is setting focus to another widget, thus triggering the OnLostFocus on the text area.
If that doesn’t identify the issue then would you mind attaching your file so that we can take a look? Thanks!
