Hi
I wanted to open rpteam file alone, I have some linking missing and could not fix it while working now alone without colaboration.
Hot to change the file to edit it alone?
Hi
You’ll need access to the server which is hosting the .rpprj (teams) file, or a local copy of the .rpprj file (for example, if you already joined the Team Project, you have a local copy.) Open the .rpprj file, Choose File > Save As… choose a filename and location, and it will create a separate .rp (individual Axure RP) file which you can edit yourself.
