I just opened a prototype created in AX8 in AX9. It had some boxes with rounded corners and an outer shadow. These seem to have gone a bit odd. The setting shows 0 for the rounded corner and the shadow doesn’t have a rounded corner even though the box still has it visually. I created a new box and that worked fine.
Hi ajacobsuk,
I tested creating a box with rounded corners and an outer shadow in Axure RP 8 and then opening the file in the 9 beta, and everything transferred over correctly. Since the issue sounds specific to your .rp file, could you post that here (in Axure RP 8 file format) so that I could take a closer look?
Hi Jane
Sorry, I just did a bit more digging. Now that the Outline pane has moved, I didn’t spot that the box was actually a dynamic panel. So I was working on the dynamic panel and not the rectangle.
Thanks
Andy
