Outside border only on submenus
I’m trying to get only the outside border on submenus to show up, not the horizontal lines between each item. On one of my mockups, I somehow managed to get this to work, but for the life of me I can’t recreate it. Border visibility isn’t an available option in the menu widget. Does anyone know how to get this to work?
Hi! Are you aiming for a result like this?
2019-03-12_1608
If that’s what you’re after, then you’ll want to click each menu item and pick “None” for the border thickness to turn off the borders for each item:
2019-03-12_1610
You’ll then want to select the menu widget itself (it should show a green highlight all the way around) and apply the border thickness that you want for the whole widget; this should result in the border surrounding the whole menu rather than each item:
2019-03-12_1611
Hopefully that helps!
