Overwriting a master with item data inside a repeater?
Hi there,
I have the following problem: I’m using several repeaters with the same item layout on different pages. A very common use case for repeaters, I think.
is it possible to use a master inside a repeater and overwriting some widget attributes with the item data?
I don’t want to break away the master.
Many thanks in advance! :slight_smile:
You can’t modify repeater from the outside, but you can program the repeater to modify itself from inside.
You can create a loop like
onLoad –
  1. set text on widget to Variable Value
  2. wait 50ms
  3. fire event onLoad
In this case, if you modify the Variable Value, repeater will adjust itself according to it.
