Passing image to another page
I Have a problem in passing image to another page using dynamic panel
Hi swarupk,
Welcome to the forum! Would you happen to be following this tutorial?
https://www.axure.com/support/training/set-panel-next-page-tutorial
Let me know which step that you’re running into trouble and attach a copy of your RP file. Happy to take a look :).
Hi Alex,
Thank you for your replay. Please find attachment.
if i click on grey button grey should pass to next page , if i click on blue button blue should be pass to next page
Example.rp (55.4 KB)
Hi there,
I see. You’re on the right track by setting up the global variables in the project. Instead of having separate variables for grey and blue, though, it may be easier to use a single variable that you set to match the panel state names of the target DP.
This screenshot shows the added Set Variable Value action on page 1; make sure to order it before the Open Link action:
On page 2, you’ll want to name your panel states so that they match the values being set in the Set Variable Value action:
Then on the DP, you can create an OnLoad case that sets the panel state to the value of a variable:
Changes in the RP attached: Example_Edit.rp (57.1 KB)
For more background, check out steps 2-4 of the tutorial as well:
https://www.axure.com/support/training/set-panel-next-page-tutorial#step_2:_set_global_variable_value_when_radio_buttons_are_selected
Hope that helps!
Thank you so much for your help Alex … :slight_smile:
hi alex , not getting Please check attached screenshot
i got it … thank you alex
