Pin to Browser doesn't work when I Scale to Width
Hi there,
I like the new Axure9 prototype player, good job! The only problem that I’m having is that the Pin to Browser functionality is disabled when I select the Scale to Width option.
Is there a workaround?
Thanks.
Hi Levi,
That sounds strange! Could you post a screenshot or an example .rp file where you are running into this behavior? And it sounds like you are seeing the “Pin to Browser” functionality disabled in the actual Axure RP editor, and not in the browser output, is that right?
Hi Jane,
Thanks for the quick response. The problem happens in the browser output, when I preview the prototype. I’m using Chrome. I made a gif and I’m also attaching the axure file: pin test.rp (44.9 KB)
Hi Levi,
Ah! Got it. Thanks for clarifying and for the sample .rp file. I was able to reproduce the same issue in a new file, and I’ve gotten this filed with our QA team.
Let me know if you see anything else!
