Good evening, I have the problem that when I create a DP in the DP that then gets the Pin to Browser function, this inner DP is previewed at the top of the browser. Is there a solution?
Pin to browser in a DP
mbc66
#2
Not sure I understand your question or what your objective is here.
Could you upload an .rp file, and/or screenshots to demonstrate your issue or the results you are trying to achieve? If not, then at least some detailed steps to recreate it?
So, you have created a dynamic panel, right? Then, inside that dynamic panel, you have created another dynamic panel. Which panel have you pinned to the top of the browser? Outer? Inner? Both? What is your problem? How exactly are your two dynamic panels placed in the HTML now, and how do they behave? How exactly do you wish them to be placed or behave?
