Pinning object to the bottom of th epage
Im trying to create a footer which is pushed to the bottom of the page content when an accordion is fully opened. The return to the bottom of the page when all accordion are closed.
You could use the ‘move’ action to move the footer down. In order to detect, when to move it you could create a variable that is increased by 1 each time an accordion page is opened and decreased when closed. You also issue a move(0,0) on the footer.
On the footer you then react on the Moved event and create a condition for the counter. If it surpasses a certain count then you move the footer to the bottom, or you move it back up, if the counter decreases below a certain value.
HI Yaba, - Thank could work, I shall give it a go.
