Please solve the file error
I am currently using axure9. If someone else opens the file after the update, it will not open and the update function will not be applied, so it will look different from the actual file. I don’t know the cause, please.
I highly recommend you send your question to support@axure.com and attach your .rp file. They should be able to help you.
