I have two pages (actually Panel States), where on the FIRST panel state is a repeater table and the SECOND panel state is a form. The user is able to select rows from the repeater table (checkbox) and, once a button is pressed, I need the names (column LastName) to populate respective Text Fields on the following panel’s form (LastName 1, LastName 2, LastName 3) - only doing 3 instances, because, prototype.
My thoughts were to add each of these LastName instances to a string/array within a Global Variable - SelectedLastName:
[[SelectedLastName]],[[item.LastName]]
and then do a .split method to parse out each instance from some trigger on my second panel state.
onMove
Set text on LastName 1 to “[[LVAR1.split(‘,’,2)]]”
where LVAR1 == SelectedLastName. Or something like this for each Text Field LastName instance.
I’m good with trying not this, like using another Repeater. Anything really.
