Print only pop up?
On clicking Print button on a pop up, is there a way to grab only popup and print it?
It sounds like you’re using “Open Page in Popup Window” to open a popup in the browser, and want to print only the popup dialog’s content–is that accurate? If so, then you should be able to right-click the popup window and choose “Print” to print it. Would this do the trick for you?
Thanks for reaching out, Alyssa. Actually this trick is not going to work.
