Pull Widgets From Right Not Working. (Bug?)
Hello,
I have a simple box on the left that collapses using DP state 1 and state 2, and a box on the right. When the left panel collapses to state 2, the box on the right should pull to the left, but it’s not. I’ve tried everything, but can’t get it to work. test.rp (59.5 KB)
Thanks for any help.
Hi @anon69228960 if you right-click the dynamic panel and choose Fit to Content - that should do the trick. This will ensure that the panel hugs the contents of each state, allowing the push/pull to be visible when switching between the wider State 1 and narrower State 2.
Hi Frankie,
Thanks for your help… it works perfect! So simple, but completely missed it.
Steve
