As far as I can tell, using “push / pull widgets” does not work when using nested dynamic panels. Even though all panels have “Fit to content” selected, when a panel changes size, nothing outside of that panel gets pushed.
Example: push pull widgets test : http://iz2xog.axshare.com
In the prototype, select “Composite” in the “Directory Type” dropdown. Then select “Schedule” in the “Publish Method” dropdown. The buttons (“Add” and “Cancel”) do not get pushed down.
Now select “Once a Week” in the “Publish” dropdown. None of the content below gets pushed down.
[ATTACH]12650[/ATTACH]
(Axure .rp file is attached)
Several coworkers have had the same problem. Unless I’m missing something, I think this is a bug. But maybe someone has a trick / workaround for the time being? If so I would greatly appreciate it…
thanks!
p.s.: We are on Axure v8.0.0.3297
push pull widgets test.rp (132 KB)
