Push/pull widgets when repeater gets filtered
Is there a way to push/pull widgets below a repeater when the items in the repeater get filtered?
Yes. You can’t do it with push/pull, but this works. Place the repeater inside of a dynamic panel that’s set to Fit to Content. This panel will change its size to fit the repeater’s size when the repeater is filtered.
In the dynamic panels On Sized event, add this code
On Sized (of Fit to Content dynamic panel)
  Move whatever to [[This.bottom + 10]]
“whatever” above is the thing you want to move. If it’s a bunch of things, you can group them and move the group. It will stay 10px below the repeater.
