Real Time HH:MM format
I want to present time in 24 hour format HH:MM.
I have tried using [[Now.getHours()]]:[[Now.getMinutes()]]
From :00 to :09 the minutes past the hour are present as a single digit HH:M
Does anyone know how to present :00 to :09 the minutes past the hour as two digits instead of one?
You’ll need to use two cases with a condition to determine if the minutes are equal to 0-9. Then in that special case you’ll use this:
0[[Now.getHours()]]:[[Now.getMinutes()]]
Hi Nathan,
this is one you will really like:
[[Now.substr(16,5)]]
Best
Gregor
Not sure how this works but it does - saves creating two conditions for single and double digit HH and MM
Exactly.
The complete “now”-string contains the correct time in hh:mm (starting at character 16 of the string and has 5 characters = substring(16,5))
Ah great idea, Gregor. I hadn’t thought that Now would contain the zero.
Thanks - works really well.
How could i achieve the format HH:MM:SS using substring?
[[Now.substr(16,8)]]
To achieve a real-time YYYY : MM : DD HH:MM:SS I have used:
[[Now.toISOString().substr(0,10)]] [[Now.substr(16,8)]]
What would I need to show the current time subtracted by 36 hours?
[[(Now.addHours(-36)).toISOString().substr(0,10)]] [[(Now.addHours(-36)).substr(16,8)]]
You can add or subtract using a positive or negative number (where n is a number):
hours .addHours(n)
minutes .addMinutes(n)
seconds .addMinutes(n)
I am currently prototyping a design where you can see when a train will arrive at each station so I would like to simulate the
‘current time’ +0mins at station A
‘current time’ +2mins at station B
‘current time’ +4mins at station C
and so on, so it look like this
Station A
12:00
Station B
12:02
Station C
12:04
Im currently using [[Now.substr(16,5)]] to pull in the current time, but im stuck on how to make it add minutes on.
Station A
Station B
[[Now.addMinutes(2).substr(16,5)]]
Station C
[[Now.addMinutes(4).substr(16,5)]]
