I have been searching for quite a while now and have not been able to find my answer. It seems simple enough.
I have a repeater with several images + text. The entries in the repeater will have some repetition, and rather than loading this images into that repeater (they are separate from the CSV file with my “text” data), I would like to have a “database” with all the images, then have a “function” that can retrieve the image that I need based on the name of the part (name of part will be same as the image file “name_of_part”.png.
I tried using a filter on my source repeater to only have 1 row showing. There doesn’t appear to be a way to specify which row you would like to update using a variable (the Row field seems to be only hardcoded values which I find strange.
Anyone able to help me out or point me to a solution.
