Repeater Count IF == "X"
repeater-widget
#1
I have a repeater table and one of the columns has a droplist menu where the user can set the status e.g. ‘Attention Required’.
I would like to be able to count the number of rows (items) that have ‘Attention Required’ set and have this display above the table e.g. ‘Attention Required: 3’
This would be a foreach loop of sorts but I can’t workout how to do this in Axure or if it’s asking too much of a prototyping tool
#2
You could filter your repeater and then count the displayed item with “itemCount”:
CountFilter.rp (52.0 KB)
Best,
PS: Hope you will be able to open the prototype with RP9, I made it with RP8 :confounded:
#3
Yep it opens in RP9.
This is almost what I want but I’m looking to see the values for A, B and C on page load not when filtering. So something like
A: 6
B: 3
C: 4
#4
Ah ok,
You could sum it up onItemLoad:
(add 1 each time it’s the value you are looking for
if A => +1
if B => +1
CountFilter_V2.rp (53.1 KB)
#5
Perfect! Thank you for the help
closed #6
