Repeater - faceted search - filter by range
I’ve constructed a repeater with three faceted filters.
  • Each facet is a checkbox which has ‘Update Rows Set None where “[[True]]” in (Repeater)’ applied to it.
  • The filters are a series of local variables [[ (!r1) || (r1 && Item.Status == ‘Open’) ]] where r1 is both the name of the widget and the local variable. Each variable is widget ‘is selected of’ variable.
  • The fourth filter is affecting a column of numerical data indicating the number of days since an event 1 - 10, 1 - 30, 1 - 60 etcetera. I have tried to apply the filter [[ (!c1 ) || (c1 && Item.Modified > = 10) ]], but this doesn’t work.
Edit: Had the comparison operator wrong. It should have been [[ (!c1 ) || (c1 && Item.Modified <= 10) ]]
