Hi
I am being driven slowly mad by what seem to be intermittent issues with Axure prototypes not obeying the ‘rules’ in terms of event loading and interaction execution. A prototype I was working on was working exactly as desired for about 2 hours, then, with no change to the file itself except closing and opening, it now ceases to work the way I would expect it to. I can’t tell if this is me, my computer, or a n axure bug in v9.0.0.3707 Mac.
The problem:
I want to use cases to set a filter on a repeater on page load. The case takes a variable value and applies a repeater filter based on this. Once the filter is applied, I want to update a variable with the visibleItemCount so that I can render it in a text object.
I have found a number of oddities:
- Using onpageload to set the filter and subsequently set the variable/text values always fails. While the filter is applied, the visibleItemCount does not get set. It only happens on the onload page event, so it may be a conflict with the timing of the repeater’s load event, but I’m not sure.
- If I use a click action on a button on the page then it all behaves as desired.
- If I try to fire a click action using “Fire Event” on the same button, inside the onpageload event, it does not work.
Any ideas?test-load.rp (176.9 KB)
Please save me from going completely mental. I’ve been at this for hours (and hours)
