I’m pretty new to Axure and I think I may just be missing something with my syntax here, but I’m trying to setup a repeater filter and it’s not working. I could use some help.
I have 4 columns in the table which can have one of 3 possible values: 0, 1, or 2. I have set up a filter that I want to use to show only rows that have a value of 1 or 2 in any of these 4 columns.
Here is the expression I’ve written:
[[Item.HR!=0 || Item.MAP!=0 || Item.SP02!=0 || Item.RR!=0 || Item.TEMP!=0]]
Problem is, when I click the button that applies this filter, it doesn’t actually filter anything. It definitely is doing something - I get a few seconds of the machine working hard to process the command - but no rows end up getting filtered out.
I tried escaping the zero with single quotes and double quotes, but no change. I also tried adding spaces between the logical operands, still no change.
[[Item.HR != '0' || Item.MAP != '0' || Item.SP02 != '0' || Item.RR != '0' || Item.TEMP != '0']]
Where have I gone wrong here?
