Repeater Master & OnItemLoad option
Hi there!
how to add ‘OnItemLoad’ option to the repeater master?
Hi Adam_K,
If you have a repeater inside a master widget, you can edit its “OnItemLoad” event by opening the master in the canvas for editing (you can do this by double-clicking it in the “Masters” pane) and then selecting the repeater in question. The OnItemLoad event should be available by default under the “Properties” tab of the “Inspector” pane:
I hope this helps!
