Repeater + Text Field = Counting based on user input
Hi guys,
I have spent a significant amount of time to find out if it is possible to put Text Field in Repeater and based on user input I would like to sum what the user wrote into all Text Fields in the Repeater. I would like to react on user input dynamically. If the user will delete the number from any of textfield, the Sum amount will be updated.
Can someone navigate me?
Thanks for the response,
S.
See this example:
Summed Repeater.rp (65.2 KB)
The Home page wlll concatenate text fields in a repeater. Page 1 will sum numerical text fields in a repeater, and the sum will update dynamically.
This approach uses the method of a “hidden function” in the repeater widget, using its OnMove event. When you trigger an event for a widget in a repeater, then it will get triggered for every row in the repeater, successively, from first to last. This can be used for summing, concatenating, etc. of all rows in the repeater.
Nice, thank you so much for the help :slight_smile:
