RP 9 Licenses + Backwards compatibility
Hey there,
Apologies if this is said anywhere else, but I have a query re: RP 9’s license and compatibility.
Currently, I can use RP 9 Beta with my existing personal and work licenses.
Once 9 exits Beta - will this still be the case?
Will we lose access to the full RP 9 app, but still be able to open and use the RP 9 Beta app?
Also, can files created in RP 9 be opened with RP 8?
I only ask because I’d like to use to RP 9 Beta to create quite an in-depth master prototype for an iOS and Android app.
Thanks,
Will :slight_smile:
Hi Will, We certainly appreciate that you want to put RP 9 through the paces! However, it sounds like this project might not be the right fit for a couple reasons. In answer to your questions:
  1. The beta comes with built-in expiration timing, so builds only last a certain amount of time before requiring an update/new build. You wouldn’t be able to work in the beta after the full RP 9 is released.
  2. There isn’t backward compatibility from RP 9 to 8. If this were to become possible, note that you would lose any of the new features from 9 (text styling on form fields, master overrides, etc) in an RP 8 version of the same file.
Thanks Rachel, makes a lot of sense.
Hi Rachel!
Will I be able to open my Axure 9 beta files in in fully released Axure 9 ?
When is axure 9 is planned to be released?
Hello! We don’t have a projected release date yet, but expect the beta to last several more months. We won’t break your RP 9 beta files; anything you’ve created during the beta will work in the full RP 9 once live!
