RP11 drag canvas performance issue
As shown in the video, RP11 will experience severe freezes when holding down the spacebar and dragging the canvas. But if you drag with the middle mouse button, this phenomenon does not occur.
This problem has been bothering me for weeks. I tried reinstalling the Windows 11 system, Windows 10 system (both are the latest versions), and updating the driver, but nothing solved the problem.
If you need more information about my operating environment, please let me know.
如视频所示,RP11在按住空格拖拽画布的时候,会出现严重的卡顿。但如果是用鼠标中键拖拽,则没有这个现象。
这个问题困扰了我几周了。我尝试了重装windows11系统、windows10系统(两者均为当前最新版本)、更新驱动,都无法解决。
如果需要更多我的操作环境的信息,请告知。
13th Gen Intel(R) Core(TM) i7-13650HX   2.60 GHz
Nvidia 4060 Laptop
32.0 GB
版本	Windows 10 专业版
版本号	22H2
安装日期	‎2025/‎1/‎6
操作系统内部版本	19045.5247
体验	Windows Feature Experience Pack 1000.19060.1000.0
PS:video cannot be upload, if video is needed just let me know, i will upload to youtube and paste link.
(by google translate) Update: After checking the hardware again, I found that the problem was that my CPU hit the 100°C temperature wall, which caused the lag. This was the main reason. However, only dragging using the space bar + left mouse button will cause lag, but dragging directly with the middle mouse button will not. This is one; second, there will be no lag when opening the same file using RP10. So this still counts as a performance issue, my own computer’s CPU issues just amplified it.
情况更新:经过再次检查硬件,我发现问题在于我的CPU撞上100℃温度墙了,所以导致的卡顿,这是主要原因。但是,只有使用空格键+鼠标左键拖拽存在卡顿,鼠标中键直接拖拽则不会,这是其一;其二,使用RP10打开相同文件也不会卡顿。因此,这依然可以算作一个性能问题,我自己电脑的CPU问题只是放大了这个问题。
问题解决了,微信输入法的锅!我已经反馈给微信了。搜索到这条的朋友,如果你也在用微信输入法,那么切换到其它输入法(例如微软拼音)或英文模式就好了。希望能帮到你们,毕竟官方没有测试环境,很难发现这个问题。
Problem solved, the pot of WeChat input method! I’ve fed back to WeChat. For those of you who searched for this entry, if you are also using WeChat Input Method, then just switch to another input method (e.g. Microsoft Pinyin) or English mode. I hope this helps, after all, it’s hard to find this problem without an official test environment.
这都能被你发现啊……从来没用过微信输入法。
是啊,坑了我好久啊,重装系统、换硬盘、最后买了个新电脑。但是每次我都很自然先安装微信输入法,所以一直没发现到底为啥。
