Can you help with one problem?
I need to click on “Extension”, so:
Selected row (Checkbox1) and State is not ddd:
show group Test1.
Selected row (Checkbox1) and State is ddd:
view group Test2.
Thank you
Tom
Test.rp (691.4 KB)
show group Test1.
view group Test2.
Thank you
Tom
Test.rp (691.4 KB)
I added this logic to “onMove” of checkbox1 inside of the repeater:
Then, on click of the “Extension” text, added an event to move checkbox1 by 0,0:
This works as when you fire an event on an object inside a repeater from outside of the repeater, it gets fired on each row. So when you click extension, it will evaluate that logic for each row.
Test.rp (693.8 KB)
Note: I wasn’t sure what’s supposed to happen if more than one is selected… if you check a row that is not ddd and a row that is ddd, both will show up.
Hi UXProtoTyper,
I copied this test on my prototype, all is ok.
But If I check a row that is nod ddd and row that is ddd, so only test1 show.
Thank you
Tom
Tom,
Please excuse me if I misunderstood, but this version will show test 2 if ONLY state DDD is selected.
I added logic on move to only show test 2 if test 1 is not visible. I also put l logic on show of test 1 to hide test 2 if it’s visible.
Test.rp (695.2 KB)
Thank you, super
I have the ending question. That situation will be the same, if I do not check the row and click on Extension so you will not see Test 1 and Test 2. The same I would like when i click Delete. (if do not check the row, so will not see Test1 and Test2)
Thank you
