Hi there,
I know it’s possible to set the value of a variable equal to the text in a Text Field widget. However, is it possible to set a variable equal to the hint text within a text field?
Reason being - I’m trying to create an Axure library and make it simple for designers to use floating labels. Ideally, anyone should be able to type a new Hint for a text field, and see the interaction. I’d imagine this would require passing that entered text from the Hint field into another rectangle that I’m designing.
Thanks for your help!
Cheers,
Jason
