Setting size for rect with image fill doesn't update repeat & stretch values
Hi there, if I set size of a rect with image fill (via interations), it does not update the repeat & stretch value. Basically, the fill-image stays with the same width and height.
Steps to reproduce:
  1. create a rectangle of any size
  2. set fill of the rectangle to image > select image
  3. set repeat & stretch options to “stretch to cover”
  4. On page level, create “Window resized” event > add action “Set size” > set new dimensions
    Result = the rectangle gets resized but the fill-image not.
Can someone check? Thnx :wink:
