I need some help with a slide.
I want to click on the pink cursor en drag the pink slide over the grey area.
Can somebody help me out?
Thank you !
Thank you !
I’m not sure I understand what you mean by “pink cursor” …do you mean anywhere on the pink area? Wherever the click target is, you can use one of several methods and actions, depending on how you have set up your prototype. You could use the Move action, Resize action, or Change Panel State action to make the pink area the same size as the “screen” (gray + pink areas as shown.)
It might be easiest to demonstrate this if you could upload an .rp file with your set up. Or, I could create a little demonstration if you need.
