Sliders co-related
Am trying to get the “real_green” and “real_red” sliders height to adjust with the location of “handle”.
meaning: as user drags “handle” higher, both real green and red are adjusting their height to match the location of “handle” (it only moves on “line2”
Also i wanted to adjust the text opacity so when slider’s height reaches a certain height (10% label for instance) only the text in this height (in this case 10% and -6%) will be enabled.
I saw the other examples, wanted to have the “Handle” position reflected in “height” text field and use that to control everything else. Can’t get that to work, numbers are going backwards and are limited to 160.
Thanksdepended_slider.rp (56.4 KB)
@rafodepended_slider.rp (57.3 KB)
Not sure if this is what you are looking for, hopefully it will point you in the right direction.
