This is going to seem like a really strange question David, but by any chance is the prototype file that you’re working with a file that was originally created on Axure 6 or 7 or is this behavior reproducible on a brand new prototype created with AX8?
I’m asking because i’m tracking a major problem we’re seeing where a prototype that we originally created in AX6 and was then upgraded to 7 and subsequently to 8 is not rendering styles correctly when we’ve created a team project on Axure Share Enterprise Server. If I render the prototype locally, it works fine. It’s as if there’s something in the guts of the RP file that originated from a version prior to 8 that is causing some kind of incompatibility in how AX Share Enterprise Server is rendering the prototype.
I’ve gone so far as to literally delete every page (including masters) from the problematic file, placed a single element on a single page (such as a form input widget). As long as the widget has some type of style (such as a fill color), it will not render correctly after I check the file into the enterprise server team project. The fill color will be missing or the border won’t show. Whatever style i place on the item/s don’t render correctly. It appears that styles are not linked properly. As if the html can’t locate the CSS that is supposed to be styling the page.
Just curious to see if your scenario is similar…
