Had a question with focus on a text input widget. I essentially want it to select the text in the input box when you click on (e.g. focus) on the widget and all works well.
The problem is that when I start to type text to replace the highlighted text and then hit the space bar, it highlights the text that I just typed and overwrites it with the text I continue using after the space (e.g. if I type “Hello there”, the “Hello” is highlighted and replaced with “there” after I hit spacebar. Seems like a bug? Why can’t it support multiple words?
