Sticky Footer, Aligned centered without min width
Whats the best way to center a sticky footer that stays at the left edge even when the window gets smaller than the content?
Is there a solution that works within a contained panel. Without referring to the onWindowResize functionality?
Heres an example (with onWindowResize sadly :frowning:
Thanks for your ideas.
Hi @Zuvala,
You could achieve it with a bit of “Pin to Browser” and "100% Wide (browser only):
and an Adaptative view:
Here the result:
Sticky - Pin to browser adaptative.rp (51.8 KB)
The idea is that:
  • Dynamic can be pinned (top, left, bottom, …) and can automatically take the width of the windows
  • When the windows width is too small one need to change the behaviour and make the blue Dynamic panel pinned on left and not centered
Best
Thanks for the ideas :slight_smile:
You’re welcome :smile_cat:
