For me personally, the batch spacing feature is rarely used, 99% of the time by mistake. In the past, when I wanted to move multiple objects, I would just batch select them and left click and drag. And now my operation is usually:
- Select multiple objects
- Left click and drag a distance
- Realize that I accidentally clicked on the batch spacing hotspot
- ctrl+Z to undo the operation
- Mouse back over those objects again and move them around the edges carefully avoiding the red bulk spacing hot zone.
If I’m not in the minority like this, I’d like to be provided with a switch to turn this feature off.
PS: Why don’t I personally use this feature? Because this feature doesn’t intelligently recognize higher level holistic objects made up of multiple objects, it still relies on grouping. Since I’ve grouped them separately, I just drag the most marginal objects farther away and use the automatic horizontal/vertical distribution feature.
(DeepL translate)
对我个人来说,批量调节间距这个功能很少使用,99%的情况属于误操作。以前想要移动多个对象时,直接批量选中它们,然后左键拖拽就行了。而现在我的操作通常是:
1)选择多个对象
2)左键拖拽一段距离
3)发现不小心点击了批量调整间距的热区
4)ctrl+Z 撤销操作
5)鼠标再次回到这些对象上面,并小心翼翼地避开红色的批量调整间距的热区,在边缘处移动这些对象。
如果我这样的人不是少数,我希望能提供一个开关,让我关掉这个功能。
PS:为什么我个人不用这个功能?因为这个功能并不能智能识别由多个对象构成的更高级别的整体性对象,它依然依赖于编组。既然我都给它们编组了,那么我只需要将最边缘的对象拖远一些,然后使用自动横向/纵向分布功能就好了。
