Transfer an image from a repeater to another page if selected
Hey Guys!
I have a Repeater in which i list Products, of which you can only select one.
I would want the image of the selected row to be displayed on the next page for customization.
Is that possible in any way?
With best regards,
Tobias
Yes! on Page 1, set a global variable and change it OnClick in the repeater, and then onLoad on the second page, change the image based on the variable value.
carryover_image.rp (1.0 MB)
First of all thank you so much for the help.
Does this also work if the different Images are not set as Dynamic Panels? But with images that are added into the Repeater properties ?
Yes, there are many ways you can achieve this based on how you setup your prototype.
Here is the example where images are set as a repeater property. But with this solution, you have to copy the same repeater on to the second page. You can try converting the repeater into a ‘master’ to avoid copy/pasting each time you make a change to the repeater on the first page.
Check the page-load time to before you choose one method over another.
carryover_image.rp (1.2 MB)
Hi @praveen.naga,
Welcome to Axure forums! Nice solutions.
I have updated your solution and made a compact version by getting rid of extra cases and redundant conditions.
Have a look.
carryover_image_updated.rp (1.0 MB)
Cheers!
Thank you guys so much! you’ve been a great help to me !
