Trigger Action from within a Master to Show/Hide widgets/groups outside the master
Hi there,
I have a modal with multiple masters as content blocks. They are effectively forms and labels. But i made them masters as i have to use same arrangement in different pages/modals.
I want to be able to show / hide other group / master (outside this master) when a user change the droplist selection.
I read some points for raised events, but could not get what i needed.
and i hope my question is clear…
You’re correct, you need to use raised events.
In your master, on the event that you want to trigger the action, add a raised event. For example, if you have a droplist in your master, you might add a raised event to the OnSelectionChange event and give it a name. You can even add multiple, conditional cases with different raised events depending on which option is selected.
OnSelectionChange
If selection is Option 1
Raise event OptionOneSelected
If selection is Option 2
Raise event OptionTwoSelected
Now when you place your master on the page, you’ll see two events on your master: OptionOneSelected and OptionTwoSelected. Then you can add cases and actions to each event.
OptionOneSelected
Hide widget
OptionTwoSelected
Show widget
Thanks @nkrisc Let me give it a try,
