I’ve been using Axure for several years now and there’s one thing about the repeater-widget that I’ve never tried to use because I don’t really understand how it should be used: TargetItem.
The online documentation says this:
TargetItem is a similar object that gives you access to all the same properties as Item. The difference between the two is that you can use TargetItem in an interaction on a widget inside the repeater’s item to access information about other items in the repeater.
But what does that mean? How does one apply it / use it within the contents of an item to access information from the other items? Perhaps all I need is a concrete example but I’ve searched on line on and off since I first started using repeaters and have never found anything - no blogs, no videos, no forum posts/answers - that have such a thing.
Any help would be greatly appreciated!
-Jenni
