Unable to change text color when button clicked
I am trying to change the color of a string when a button is pressed. I found the topic discussed that pointed me to the Rich Text option. Using that I am able to change the text, and the alignment, but the color, font, and font size are not set. Can someone tell me what I am missing?
Color Test.rp (45.1 KB)
Hi! It looks like you had your rich text interaction mostly set up correctly, though the interaction hadn’t specified the color red for the text. To do that, you’ll want to open the rich text window, highlight the text, and then use the color menu to apply the red to that text. That should do the trick!
