Hi there, I work a lot with styles in Axure.
I get that when you modify the properties of a widget that already has a style attributed to it, an asterisk appears next to the style name.
The issue I’m having is when trying to ‘reset’ the style. For example:
[ul]
[li]I create a style for a widget called ‘My Button’
[/li][li]I then modify the properties of that widget, and an asterisk appears to indicate that I’ve changed the ‘My Button’ style
[/li][li]I want to reset the widget to use the original ‘My Button’ style, so I select the ‘My Button’ style in the Style dropdown
[/li][/ul]
The issue is that sometimes this reverts the style back to how it was, and sometimes it has no effect - the style on the widget remains modified from the original, with an Asterisk next to it.
Even selecting a different style and then selecting ‘My Button’ again doesn’t work.
I know I’m missing something!
Thanks for any help
