Use Interactivity to dynamically switch between applied Widget Styles?
To suggest new features, complain about current features, etc. send an email to support@axure.com --they don’t like us to use the forum for that anymore. I guess we’re collectively too much like fourth graders :rofl: Ha ha! Loved that comment in your other post… Seriously though, they are good at responding to emails.
In the meantime, I recommend using a Selected state for each of your widgets. The default/normal/unselected state can be set to “WidgetTestStyle1” and the selected state can be set to “WidgetTestStyle2” Then your button can have an action to “Set Selected of [widget] to toggle” for each widget. The selected styling will carry across to Masters and Widget Libraries.
If you are concerned with having to select every widget on a page as targets for your button click action, and then having to repeat on all your pages, then I can think of a few approaches you could try…
Once you are done designing a page, group all the widgets on the page (Ctrl+A then Ctrl+G) and then have your button set this group to “selected.” This may not work so well for “massively complex” prototypes.
Or, build a conditional case into each widget so it can take care of itself, in an object-oriented fashion. I would try using the Loaded event with a conditional case to test the value of a global variable, like OnLoadVariable. In your case it might look something like, “IF value of OnLoadVariable equals “dark” Set This to Selected.” You can copy and paste this Loaded event from widget to widget as you are building your widget library. Then, your “theme button” can simply set OnLoadVariable to “dark” (or blank for a default Light Theme) and reload the current page. Subsequent pages would keep the current theme as they load, as long as the widgets are dragged in from your library with their Loaded event.
Here’s a couple recent threads on this:
