Hi EdwardB,
As a base I used file that posted on this page, please scroll up to see: AccordionRepeater2.rp.
I really like the structure of this file.
Here my file for your reference.Nav_ref.rp (1.1 MB)
Thank you Nathalie, thatâs really nice of you !
Will try looking at your file ! will keep your posted
I can think of more efficient ways to represent your repeater table, but what you have should work⌠The example @bermanatalie posted works well, but Iâm not a fan of all the global variables, so I attempted to make a solution that didnât require these.
zalandoLike-Nav-v2.rp (470.6 KB)
First off, you should name your widgetsâotherwise the interaction code gets too confusing. For example, there is a Label rectangle in each of your dynamic panel states, so they might be named âL1Labelâ, âL2Labelâ, and âL3Labelâ⌠Secondly, your table is not in the correct order⌠Look at what is shown on the Home page in Axure editorâSome of your Level 3 items are above their Level 2 and Level 1 parents, so when shown they would appear above their parent itemsâopposite of what you show in your example GIF here. I resorted (in Excel) so the accordion structure displays correctly.
Third, you have a filter rule that does not make logical sense:
[[Item.stateLevel == 2]] == [[TargetItem.Level1]]
âŚSo when you click on a Level 1 item, everything disappears.
I get what you are trying to specify here, thoughââShow Level 2 items under this item, and all Level 1 items.â
Basically, you can have only one statement in a Filter rule, entirely wrapped in the double square-brackets (rather than two sets of the double square-brackets.) The way a filter works is it will display only the repeater items that exactly match the rule. So the filter logic for this rule should look something like,
[[ Item.stateLevel == 1 || (Item.stateLevel == 2 && Item.Level2 == LVAR1) ]]
where LVAR1 is a local variable pointing to the text on the itemâs level 1 rectangle (e.g., âL1Labelâ). The translation of this rule is, âShow item rows that have value â1â in the stateLevel column (all Level 1 items) OR item rows that have both of these conditions: A) value â2â in the stateLevel column AND B) value in the Level2 column that matches the text in this itemâs Level 1 label (meaning they belong to that Level 1 parent item).â
So, yes, the âqueryâ syntax gets complicated⌠Welcome to repeaters!
Iâm not sure why you are trying to set a Level 1 item to dynamic panel state 2 when clicked⌠This would make it appear as if it were a Level 2 item, which is not your stated intent. Likewise, when a Level 2 item is clicked, you donât want to make it a Level 1 item, but rather have the same styling as a Level 1 item. So, I set up some styles to save time and set the background and text to be selected when clicked⌠the selected state matches that of Level 1.
I had to play around a bit with the filter rules for selecting/deselecting (opening and closing) items at each level. When the interaction code was all loaded to your dynamic panel (dp) within the repeater, successive clicks got unresponsive and unreliable. I think this was due to having to repeatedly test the current state of the dp and whether something was selected or not. I broke out the OnClick code to the widgets in each of the 3 states. To make this work better, I grouped everything in each state, so clicking anywhere on an item triggers the same OnClick code. It also made it easy to specify a selection group so only one item at each level can be selected at once. You can remove any of the selection groups if youâd rather have multiple items selectable.
I also had to change how the repeater gets loaded, so look at the OnItemLoad code as well. Finally, I added carets so I could keep track of which items/levels were actually selected (and it is consistent with your sample GIF.) Now that it works, you could remove those widgets if needed.
Oh my god⌠This is insane ! Iâam so grateful for your help !
You should write a medium post for that ! Iâam so happy !
If you ever come in London UK Iâll buy you a beer
