Vertical Scroll not working in a Dynamic panel when inside another dynamic panel
Hope someone can help me here and confirm if this is a bug or not.
I’ve created the following example for an image upload system with classifications. When you click ‘Browse’ it shows a dynamic panel to set classifications, then clicking continue will show another dynamic panel with upload progress. Inside this panel is a small scrollable window to view all the uploads. This is where the problem lies.
This internal panel will not scroll on load, it only seems to scroll when a variable within the panel is updated (so if you click the dropdown and change the classification it suddenly works fine and can be scrolled easily)
Is this a bug or is there a fix for this? Any help appreciated :smile:
ScrollPanelNotWorking.rp (138.7 KB)
