Back in RP8 (I think), you could easily tell which color option was selected (it was highlighted).
Can you try to bring this back? Once again, you can’t tell which shade of grey is selected in the palette - which is helpful when you’re trying to match colors between objects.
Which Color Is Selected?
dvturner
#1
gothate
#2
Agreed.
Also while we’re on the color picker, it’s SO much better than it used to be, except that it got rid of the AX8 button+dropdown combo, which let me select a widget, “grab” the color from it (select widget, open and close color picker) and then apply to other widgets easily (select widget, click color button)
