Axure’s component functionality enables the creation of variants similar to Figma, including variations in colors and shapes. The Widget style manager further facilitates this process, making it easily achievable.
I invite you to watch this video, where I demonstrate the implementation of changing all component instances when the component is modified.
Combining the use of the components as a widget library that I mentioned in this post, you can implement changing a component instances when the component is changed.
A maintainable design system component library can be made.
FOR AXURE UPDATES
To enhance Axure’s capabilities, it would be beneficial to elevate the placement of components to a higher level and enhance their flexibility in this collaborative design era. @axure:muscle:
It would be helpful if I had the option to choose whether to use the component views’ inheritance relationships or have them function like dynamic panels, where each state does not affect the others. Such an approach would provide maximum flexibility and efficiency.
More contents in axureboutique.com
