Hey Julia,
It’s not possible to import a PSD or HTML file into Axure RP, though you may be able to import custom HTML into your file by adding a plugin on AxShare (only works for AxShare-hosted prototypes). Details on that can be found here:
Create or Edit a Plugin on AxShare Tutorial
Besides that, it is totally possible to customize the login page (both the password and AxShare login page) for your prototypes. More info on that can be found in the “Branding” section of the AxShare basics page here:
https://www.axure.com/learn/axshare/basics#u210
The same info should also be available, along with the downloadable template files, under the “Branding” tab of your AxShare account. If you’re logged in, you should be able to go straight to https://share.axure.com/branding\
You can download the templates for the custom password and login pages and design them to fit your needs. There are a few caveats though:
You cannot delete or rename the template widgets.
You cannot add animations to the widgets.
Once you’re done modifying the template file, you can upload it via the “Branding” tab of your AxShare account and that will become the page used for all logins/passwords. There’s back-end logic that happens on the AxShare servers that controls how widgets are shown, which is why you’re not able to add custom animations during the design process.
Hopefully that helps!
