Dynamic panel switching goes wrong at some point.
a bug.rp (271.3 KB)
Fix 1, remove adaptive view
Fix 2, Fit Content
So please find the source of the problem and fix it, thank you.
a bug.rp (271.3 KB)
Fix 2, Fit Content
Hi @Jorkin,
We finally got around to investigating this issue you’re seeing and can confirm this is a bug that we’ve discovered and filed before. To explain how this bug happens, the following criteria need to be met:
Switching between the second state will cause the issue you’re seeing.
Fortunately, because this issue is very niche and requires the specific criteria above to be met, there are several workarounds where breaking any of the above will resolve the issue.
We appreciate you bringing this to our attention and hope this helps!
