Hi guys!
I’m pretty stuck at the moment, trying to show some wireframes to a client from a team project - but the add web fonts button is not clickable! Anyone had a similar issue/ knows why it’s happening?
Hi guys!
Hi! If you’re working in a team project and want to edit any of the HTML generator settings (including adding web fonts), then you will first need to check out the HTML generator. At the top right of the “Publish Project” dialog if you see that it says “Checked In” then please select “Check Out” to check out the generator. This should enable all of those options that are currently disabled so that you can make your changes and check the generator back in.
Hopefully that helps!
Thank you - still not used to working in teams
