Hi there!
Unfortunately, after a lot of searching, I haven’t found a fitting solution to my problem and have been stuck for a few days now. I would be more than grateful if someone could give me a tip, no matter how small.
I’m currently in the process of creating an online grocery store in Axure for a project at university. Among other things, this should have an “add-to-cart” function. Roughly speaking, my prototype is structured as follows: on a product overview page, there is a repeater that dynamically uses products from a data set, but the products that are added to the cart should appear on a separate page.
I had tried to reference them in a corresponding repeater on the shopping cart page, but they are simply listed one after the other and I can’t manage to put “add row” in the right place. My last attempt to separate the product names with a “split” function also failed. The problem is that it should be on a separate page because I want to later add a code for each product that will allow me to track the products purchased by users via a text box that they will see at the end.
I’ve attached my current file, but I hope it’s not too confusing. ![]()
Thank you very much!
add-to-card-variables.rp (746.7 KB)
