Continuing the discussion from Adding hours in a new row of a Repeater:
I understand that any changes made to the repeater like adding is causing the entire repeater to refresh, but this is problematic when I am setting a condition for the 4th index of the OnItemLoad function. I’m trying to add a new row (item) in the middle oi my repeater, specifically the 4th index but this will change based on the adaptive view. I have a formula set to get the last index based on the width of my rectangle holding the repeater values so that the last box before coming out of view: This last box should have the value of “More”, in mobile’s case, the 4th index and so I want to add this row into the repeater as my 4th index while keeping the rest of the repeater values the same as when the repeater was first created with its values without the “More” in it. The repeater rows after the newly created “More” should simply be shifted down a row (increase their index value by 1).
[[mobileWidth / This.width]] with mobileWidth being a global variable of 320.
This is to give an idea of what I’m hoping to mimic.
